JoeJoeJoeJoe
Apr 08, 2025Tutor
Orbi 870 with CenturyLink Fiber and VLAN 201 tagging
I just purchased and installed Orbi 870 (router + 1 satellite). Is my 3rd Orbi system. I live in Seattle and have Centurylink 1Gbps fiber. CenturyLink does VLAN 201 tagging. The Orbi has a ...
- Apr 10, 2025
Thanks for your comments
After some experimenting I learned.
1) have to select VLAN tag group (not by bridge group), add VLAN 201, select all wired and wireless ports
2) can't just save the changes, must also power cycle the router
CrimpOn
Apr 09, 2025Guru - Experienced User
What does Netgear support say about installing the 870 system on CenturyLink?
That is sort of the point of providing 90 days of 'complimentary support' with purchase of a new system.
JoeJoeJoeJoe
Apr 10, 2025Tutor
- FURRYe38Apr 10, 2025Guru - Experienced User
Glad you got it working. And thanks for letting us know it works. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
