ceebee6cc
Jul 02, 2026Tutor
Orbi 872, IPv6 & Gigaclear
Is there anyone on a Gigaclear service using IPv6 on this model Orbi and can help with the settings needed? I've a case open with Gigaclear at the moment. I have a fixed IPv4 address. Using a...
Jul 02, 2026Guru - Experienced User
Does Auto config or Static work?
Does a ethernet connected PC see any IPv6 when connected to the RBR when Auto Config or DHCP is enabled for IPv6 on the RBR?
- ceebee6ccJul 02, 2026Tutor
Thanks for picking up on this one.
>> What Firmware version is currently loaded?
V10.5.20.4_1.3.5
>> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Adtran; the exact model is hidden behind a large desk ATM but the standard install from about 18 months ago.
Neither offer any IPv6 on the WAN, no.
No.
- FURRYe38Jul 02, 2026Guru - Experienced User
Would be good to get the Adran model# information.
Also can you connect one ethernet PC to the Adtran instead of the RBR and see if IPv6 is picked up by this one PC?
What region are you located?
