ceebee6cc
Jul 02, 2026Tutor
Orbi 872, IPv6 & Gigaclear
Is there anyone on a Gigaclear service using IPv6 on this model Orbi and can help with the settings needed? I've a case open with Gigaclear at the moment. I have a fixed IPv4 address. Using a...
Jul 02, 2026Guru - Experienced User
Does Auto config or Static work?
Does a ethernet connected PC see any IPv6 when connected to the RBR when Auto Config or DHCP is enabled for IPv6 on the RBR?
ceebee6cc
Jul 02, 2026Tutor
Thanks for picking up on this one.
>> What Firmware version is currently loaded?
V10.5.20.4_1.3.5
>> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Adtran; the exact model is hidden behind a large desk ATM but the standard install from about 18 months ago.
Neither offer any IPv6 on the WAN, no.
No.
- FURRYe38Jul 02, 2026Guru - Experienced User
Would be good to get the Adran model# information.
Also can you connect one ethernet PC to the Adtran instead of the RBR and see if IPv6 is picked up by this one PC?
What region are you located?
