ceebee6cc
Jul 02, 2026Tutor
Orbi 872, IPv6 & Gigaclear
Is there anyone on a Gigaclear service using IPv6 on this model Orbi and can help with the settings needed? I've a case open with Gigaclear at the moment. I have a fixed IPv4 address. Using a...
ceebee6cc
Jul 02, 2026Tutor
I’m told that it’s an Adtran 621i XGS-PON ONT. There’s nothing obvious on the front of the unit.
I’m based in Cambridgeshire, but as far as I know, they Gigaclear system isn’t region specific.
- FURRYe38Jul 02, 2026Guru - Experienced User
Ok so UK region.
NG is aware of current FW issues happening with IPv6. I recommend keeping IPv6 disabled for now until next FW update appears. Should be a v12 version that could have this fix included. Not sure when this new FW will be coming to your region. My region NA already has it and if all goes well, should be coming to the 870 series as well.Might open a support ticket with NG support as well to let them know about this if you feel the need.
- ceebee6ccJul 02, 2026Tutor
Thanks for that; I'll open a ticket now.
- ceebee6ccJul 03, 2026Tutor
I spoke to Gigaclear and they advise as below which aligns with what you suggested as well as the earlier routers being able to setup an IPv6 connection; so it looks like I'll just have to wait for the former to be fixed at Netgear. Thanks again for everyone's help here.
From our side, we have completed all checks and can confirm that IPv6 is correctly provisioned on the circuit. Our logs show that your connection has successfully been assigned the following IPv6 Prefix Delegation:
Jun 30, 2026 @ 16:06:22 Jun 30 2026 16:06:22 UTC Connect: [S1673163 (5407.7d34.92f3)] IP=216.213.190.62 IPv6NA= IPv6PD=2a06:61c1:179d::/48 Jun 30, 2026 @ 16:06:22
This confirms that the service is provisioned correctly on our network.
The IPv6 allocation we provide is a dedicated /48 prefix assigned to your connection. While this prefix remains the same for the lifetime of your service under normal operation, it must still be obtained using DHCPv6 Prefix Delegation (DHCPv6-PD). The DHCPv6 exchange allows our network to establish the required session state and correctly route the allocated prefix to your connection. For this reason, the IPv6 prefix should not be manually configured on the WAN interface.
Based on the information provided, it appears that the Netgear Orbi 872 is not successfully requesting or accepting the DHCPv6 Prefix Delegation from the WAN interface. As your previous Linksys router was able to obtain IPv6 successfully, this would suggest that the service itself is operating correctly.
Unfortunately, we are unable to provide configuration support for third party routers. We would therefore recommend checking the Netgear IPv6 configuration to ensure it is configured for native IPv6 using DHCPv6 Prefix Delegation (DHCPv6-PD), rather than any tunnel mechanism or static/manual IPv6 configuration.
If the router continues not to obtain an IPv6 prefix after verifying the configuration, Netgear may be able to advise whether this model supports DHCPv6 Prefix Delegation with your current firmware.
- FURRYe38Jul 03, 2026Guru - Experienced User
I'll post a notice when new FW comes out, or you can keep an eye out on NGs download site.
- ceebee6ccJul 10, 2026Tutor
I'm not sure how long the support ticket is supposed to take but it was raised via my account in the portal on 3rd June and despite a couple of chasers, there's been nothing but crickets so far. Is this normal for NG?
- ceebee6ccAug 11, 2026Tutor
Netgear are refusing to re-open the case they closed by mistake and they now claim that the router is out of warranty. And still no sign of the promised firmware update to get IPv6 working on my 871 model.
They really are complete crap, aren't they?
