ceebee6cc
Jul 02, 2026Tutor
Orbi 872, IPv6 & Gigaclear
Is there anyone on a Gigaclear service using IPv6 on this model Orbi and can help with the settings needed? I've a case open with Gigaclear at the moment. I have a fixed IPv4 address. Using a...
Jul 02, 2026Guru - Experienced User
Ok so UK region.
NG is aware of current FW issues happening with IPv6. I recommend keeping IPv6 disabled for now until next FW update appears. Should be a v12 version that could have this fix included. Not sure when this new FW will be coming to your region. My region NA already has it and if all goes well, should be coming to the 870 series as well.
Might open a support ticket with NG support as well to let them know about this if you feel the need.
ceebee6cc
Jul 02, 2026Tutor
Thanks for that; I'll open a ticket now.
