DenverGuy
Apr 15, 2025Aspirant
Orbi 960 - RBRE960 - WiFi broadcast only on Satellites, not on Router
Hi, I have been troubleshooting a weak WiFi issue on the side of my home closest to the router. The router is upstairs on the north side of the home (the back side), one satellite is on the sout...
Apr 15, 2025Guru - Experienced User
Got a floor layout drawing of your home and where the Orbi units are located?
Have you swapped RBS locations to see if the issue remains?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
