DenverGuy
Apr 15, 2025Aspirant
Orbi 960 - RBRE960 - WiFi broadcast only on Satellites, not on Router
Hi, I have been troubleshooting a weak WiFi issue on the side of my home closest to the router. The router is upstairs on the north side of the home (the back side), one satellite is on the sout...
CrimpOn
Apr 15, 2025Guru - Experienced User
DenverGuy wrote:
When I power down both satellites, I have no WiFi signal from the router at all. I tried rebooting, no change. I did factory resets to the router and the satellites and still no change. When I look at the network map in the app, only wired devices are connected to the router.
The 960 has no setting to control whether WiFi is "on" or "off". (There is an advanced setting to control the Transmit Power level, but the primary WiFi is always ON.) If there is no WiFi, the router is broken.
- DenverGuyApr 15, 2025Aspirant
CrimpOn I am coming to the same conclusion. When I disconnect the satellites from power or ethernet, I do not see evidence of a WiFi signal being broadcast. When I did the factory reset yesterday I did see the default " ORBI09" network broadcast for a bit and then it disappeared. I configured the router using a PC wired into the router.
FURRYe38 Firmware is V7.2.15
- FURRYe38Apr 15, 2025Guru - Experienced User
Try this, power OFF the RBS and then power OFF the RBR then back ON. Does anything show for the wifi signal coming from the RBR? If not, try a factory reset and setup from scratch, with the RBS not connected. Is a signal seen from the RBR at all after the reset and setup?
