catherine70
Mar 18, 2025Follower
Orbi 970 - Router flashing white since more then 12 hours
Hi, my router has been flashing white since 12 hours. I have tried to reset the factory setting but didn't solve the problem. Router is connected to Starlink. I was so desperate I deleted the Orbi Ap...
Mar 27, 2025Guru - Experienced User
Any progress on this?
catherine70 wrote:
Hi, my router has been flashing white since 12 hours. I have tried to reset the factory setting but didn't solve the problem. Router is connected to Starlink. I was so desperate I deleted the Orbi App to try to install from scratch. Netgear is not available and we are desperate for WIFI. Can someone help? Thanks
