00TallGeese
Oct 14, 2024Tutor
Orbi 970 - Slow Satellite Speeds
 Hello,     I have a Orbi 970 that I just installed the other day, 1 router 2 satellites.     Firmware Version: V9.12.3.3_1.2.20  Home square footage: 5,000  Each satellite is on wired backhaul, appro...
- Oct 14, 2024
00TallGeese wrote:
Each satellite is on wired backhaul, approximately 40ft away from one another
Are the satellites connected directly to LAN ports on the 971 router? (no switch involved)
Can you check the Orbi web interface, Advanced Tab home page, Click the Blue Box "Show Statistics" to see what speed has been auto-negotiated for those LAN ports?
If it reports 100M/Full (rather than 1000M/Full), there may be a problem with the in-house Ethernet wiring (often a faulty crimp on one of the RJ45 jacks).
I purchased a 100 ft. Cat6 Ethernet cable on Amazon for under $20US that I keep on hand to validate wiring issues. Temporarily string the cable through the house from router to satellite. If the speed jumps to 1000/Full, that verifies "something is wrong" with the in-house pathway, which usually consists of:
- Ethernet cable from Orbi to wall jack (often in a patch panel)
 - In-house wiring
 - Ethernet cable from wall jack to satellite
 - RJ-45 jacks in Orbi, satellite, and wall plates.
Oct 14, 2024Guru - Experienced User
What devices are you using to connect and run speed tests with?
Be sure that when you are near the RBS with a wireless device, disable it's Wi-Fi radio for 5 seconds then re-enable it. Some Wi-Fi devices, though near to a closer Wi-Fi signal can still be connected to the farther Wi-Fi signal thus giving off slower speeds and not accurate for being connected to the RBS. Make sure that your test device is connected to the RBS. Check the RBS web page or via the Orbi app.
Compare other wireless and wire devices to check speed results. I carry a iPhone and android pad when I test.
How are the RBS ethernet connected to the RBR? Directly being the RBR or is there any LAN switches or patch panels in between them?
What CAT# LAN cable is being used? CAT6A STP is recommended.
What channels are set on the RBR?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
00TallGeese
Oct 14, 2024Tutor
Device: iPhone 16 Pro
The satellites are directly connected to the router via Cat6 cables.
2.4 GHz channel: 5
5 GHz channel: 40
I cannot set the 6 GHz channel
Wifi is using both 2.4 GHz and 5 Ghz channels
Modem is a Netgear CM1000
- FURRYe38Oct 14, 2024Guru - Experienced User
I would change to channel 1,6 or 11 on 2.4Ghz. 5 is a sub channel used by the Wi-Fi system.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
