00TallGeese
Oct 14, 2024Tutor
Orbi 970 - Slow Satellite Speeds
Hello, I have a Orbi 970 that I just installed the other day, 1 router 2 satellites. Firmware Version: V9.12.3.3_1.2.20 Home square footage: 5,000 Each satellite is on wired backhaul, appro...
- Oct 14, 2024
00TallGeese wrote:
Each satellite is on wired backhaul, approximately 40ft away from one another
Are the satellites connected directly to LAN ports on the 971 router? (no switch involved)
Can you check the Orbi web interface, Advanced Tab home page, Click the Blue Box "Show Statistics" to see what speed has been auto-negotiated for those LAN ports?
If it reports 100M/Full (rather than 1000M/Full), there may be a problem with the in-house Ethernet wiring (often a faulty crimp on one of the RJ45 jacks).
I purchased a 100 ft. Cat6 Ethernet cable on Amazon for under $20US that I keep on hand to validate wiring issues. Temporarily string the cable through the house from router to satellite. If the speed jumps to 1000/Full, that verifies "something is wrong" with the in-house pathway, which usually consists of:
- Ethernet cable from Orbi to wall jack (often in a patch panel)
- In-house wiring
- Ethernet cable from wall jack to satellite
- RJ-45 jacks in Orbi, satellite, and wall plates.
CrimpOn
Oct 14, 2024Guru - Experienced User
- In-house wiring
00TallGeese
Oct 14, 2024Tutor
Thanks for your reply. It was actually super helpful. When I did as you instructed, the LAN ports that I was using for wired backhaul were showing up as "100M/Full".
I unplugged those outlets and that seems to throw my wifi into a bit of a frenzy. I got everything up and running again but now my WAN is showing up as "100M/Full" (it was previously 1000M/Full")
- FURRYe38Oct 14, 2024Guru - Experienced User
Power off the ISP modem for 1 minute then back ON. Then check WAN port speed?
CAT6A STP cabling is recommended. This differs from CAT6 UTP cabling.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
