mapotter99
May 07, 2024Apprentice
Orbi 970 - Stopped router crash by putting a USB fan on top
I've been struggling with the last couple firmware releases, up to 9.11.1.1. Every 4 days like clockwork, the router would go down and take my whole network with it. It wouldn't restart. I had to manually power cycle it.
After seeing on Reddit and on this forum that others had put a USB fan on top, I decided to try it. I put a 120mm PC fan on top so that the air is pulled up and out through the router. I have been online for 8 days now, and my Orbi has been the most stable its been since I've had it.
I'm still having some roaming issues with my iPhone, but at least the network is staying online.
I hope this helps others, and helps the engineers figure out the cause for the overheating.
CPU Load: 8.29%
Available Memory/Total Memory: 1100 MB/1743 MB
I have NONE of those things enabled. I do have the IoT network enabled with 2.4 GHz only. Straq already has my network map.
- mapotter99Apprentice
CPU Load: 8.29%
