Golf747
Oct 22, 2024Aspirant
Orbi 970 & Epsom Printer issue
egHi all I Have recently installed the latest Orbi 970 mesh sytem (replacing my ISP standard modem/router) . The main system installed with no issues and internet etc fine. Had a few issues with the...
Oct 23, 2024Guru - Experienced User
that printer was released in 2013. many new devices have issues with wpa3 that needed driver updates. Doubtful that epson would update its driver on something over a decade old. Probably why the IoT network works as its wpa2.
JWS9518
Oct 23, 2024Luminary
I agree with Plemens. That printer has been discontinued and looks like it was made in 2013. Older devices tend to struggle with the new wi-fi protocols, especially with a mesh network or router that combines the signals or manages them in some way.
I suggest connecting the printer to the IOT network which utilizes 2.4 GHZ only and allows older devices or devices that can't handle a mesh network well to connect and work.
I would also check to make sure you have the latest drivers/firmware possible for the printer. Even though it has been discontinued, you may be able to get updated drivers.
- JWS9518Oct 23, 2024Luminary
Most likely, the printer is just simply too old to handle the protocols surrounding the combined network including the security protocols around WPA3 and its combination WPA3/WPA2.
The IOT or guest network would be your best bet to get the printer to connect and stay online, even with the latest drivers that the printer has available.
