Mikeb17
Nov 06, 2023Aspirant
Orbi 970 & Xfinity Gateway
I just received my Orbi 970 Mesh WiFi System and hooked it up to my Xfinity Gateway (XFI ADVANCED GATEWAY (XB7) I have the ethernet hooked up to the Mesh Router and then running into my computer, b...
Nov 07, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- Mikeb17Nov 07, 2023AspirantI spoke to Xfinity last night about setting up the bridge and they said it was enabled, however when I check the 'Device Manager' on the app, it only shows 4 devices connected to it.
Will it only show devices that are directly connected to the Orbis Wi-Fi and not the other devices that are on the bridge from Xfinity?
How could I check to see if the bridge is working correctly on my end?- FURRYe38Nov 07, 2023Guru - Experienced User
If it's actually in bridge mode, the RBR will have a public IP address that should look like ##.##.###.### and should not see a 192.x or 172 or a 10 IP address on the RBRs web page under Advanced Tab/Advanced/Internet secion.
- Mikeb17Nov 07, 2023AspirantWhats an RBR?
Sorry, a lot of this is new to me.
