Mikeb17
Nov 06, 2023Aspirant
Orbi 970 & Xfinity Gateway
I just received my Orbi 970 Mesh WiFi System and hooked it up to my Xfinity Gateway (XFI ADVANCED GATEWAY (XB7) I have the ethernet hooked up to the Mesh Router and then running into my computer, b...
Dfran1
Nov 08, 2023Apprentice
Hi,
I have xfinity, some advice from me
NOTE: MY findings and opinion only!!
1. Never use cable supplied routers / modems
2. go to step one
LOL
I will (personally) never use rented devices from cable companies, I use the Netgear CM2000 cable modem and it is rock stable on xfinity, I have the..
1200 MBPS Download
25 MBPS Upload
They may have switched me to your upload speeds but I never see that so far...
Anyway when you rent routers / cable modems from cable companies they tend to have lots more control over your internet,
meaning..... they tend to limit speeds during high usage more , tend to have more little problems, poor wifi, etc....
hope this helps, I really find using your own cable modem and routers is best, at least for me.
