Gsosa
Oct 20, 2023Aspirant
Orbi 970 and 2 Satellites - I just got the system and also have fios.
I just got the system and also have fios. I am having the same issue. Reboots between 30~60 minutes. Orbi connected to ONT directly. I fear i may have to return the system based on this thread. Suppo...
Oct 21, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does the front LED turn PINK when this happens?
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Is Armor or Smart Parental Controls enabled?
Gsosa wrote:
I just got the system and also have fios. I am having the same issue. Reboots between 30~60 minutes. Orbi connected to ONT directly. I fear i may have to return the system based on this thread. Support has not been able to figure it out today.
