JHMB
Oct 18, 2023Star
Orbi 970 and 2 Satellites - Router dropping out ~once an hour
I setup an Orbi 970 router and two satellites about 24 hours ago and have it has been working great aside from the fact that the router loses connection to the internet about once an hour. I am not ...
JHMB
Oct 20, 2023Star
Just an update, I have been working with Netgear tech support for the past two days, and they are doing their best, but I am done with this router at this point. I am going to return it. This hassle is not anywhere near the value I need to get for my money on this product.
JHMB
Oct 23, 2023Star
I have another update. I had the system boxed up and ready to return when I got a call from Netgear customer service saying that their engineering team thinks they found a compatibility issue with my specific ONT and Verizon FIOS and the 971 router. They asked me if I would be willing to set the system back up with a slight modification, I am now running an ethernet cable from my ONT to a multi gigabit unmanaged switch, and then from that switch to my 971 router. I am then running the ethernet out of the 971 back to a different multi gigabit unmanaged switch that feeds to the hardwired backhaul for my satellites (as well as a few other hardwired drops in the house).
I wanted to document this here for anyone following along.
I will write an update 12-24 hours from now with how this new layout impacts my router restart issue.
- FURRYe38Oct 23, 2023Guru - Experienced User
Great into. I was curious about the compatibility.
What is the brand and model# of the switch your using?
Keep us posted.
- JHMBOct 23, 2023Star
I am using a D-Link DMS-108 (8-Port 2.5GB Unmanaged Gaming Switch with 8 x 2.5G - Multi-Gig) switch. The support engineer I spoke with said it had to be an unmanaged switch for this solution to work.
Update: The system ran great for a few hours but I just had back to back router reboots. I have a note out to Netgear support and while keep posting updates here up until I have a resolution or I return the system. But for anyone else with Verizon FIOS and an Arris model#: ONT1000G14 ONT placing an unmanaged switch between the router and the ONT does not appear to solve the problem.
Thanks for letting us know.
Be sure to ask NG support about debug logs if you haven't passed those already. Something that can help NG figure this out.
I've asked others about this and theres is working, however seem to have other branded ONTs and not Verizon. Sounds like something with this particular brand and model that NG needs to figure out.
I just turned debug logging on with this last round of reboots so that I can hopefully catch something useful on the next round. The support engineer did say that it is my particular make and model of ONT (Arris model#: ONT1000G14) that is associated with this issue, definitely worth clarifying that for anyone else reading through this.
- Jc226Oct 28, 2023TutorAny updates, I am dealing with this issue now
- JHMBOct 29, 2023StarThe issue was my ONT model. I returned my unit because while Netgear support engineering is actively trying to address this issue they system was unusable for me and I wasn't able to devote any more time to helping them debug and fix.
- FURRYe38Oct 29, 2023Guru - Experienced User
Good Luck.
