ccmanhattan
Feb 04, 2024Star
Orbi 970 and Carrier Infinity Touch Thermostat Model SYSTXCCITC01-A do not talk
Up graded router to new obri 970 and now Carrier Infinity Touch thermostat will not get on line. Have tried loT and main networks. Still no luck.
- Feb 12, 2024Read comments about a different thermostat and router and they used a $20 TP-link Access Point from amazon. TL-WA801N.Got it today and solved the challenge! Thanks all for the help!
CrimpOn
Feb 04, 2024Guru - Experienced User
Is the new 970 system configured with exactly the same WiFi credentials as the previous system? (SSID/password).
My experience for 20 years has been that WiFi devices connect immediately whenever they detect a WiFi system that they recognize. Would be a real shock if installing the Netgear 970 did not work the same way.
- ccmanhattanFeb 04, 2024StarFirst try was with main network with no luck. Set up IoT network and same results.
- owlynFeb 04, 2024LuminaryMake sure Access Control is turned off.
- ccmanhattanFeb 07, 2024Star
Access Control turned off? What and where is Access Control?
- CrimpOnFeb 04, 2024Guru - Experienced User
CrimpOn wrote:
Is the new 970 system configured with exactly the same WiFi credentials as the previous system? (SSID/password).- ccmanhattanFeb 07, 2024Star
Yes it is.
