ccmanhattan
Feb 04, 2024Star
Orbi 970 and Carrier Infinity Touch Thermostat Model SYSTXCCITC01-A do not talk
Up graded router to new obri 970 and now Carrier Infinity Touch thermostat will not get on line. Have tried loT and main networks. Still no luck.
- Feb 12, 2024Read comments about a different thermostat and router and they used a $20 TP-link Access Point from amazon. TL-WA801N.Got it today and solved the challenge! Thanks all for the help!
ccmanhattan
Feb 04, 2024Star
First try was with main network with no luck. Set up IoT network and same results.
owlyn
Feb 04, 2024Luminary
Make sure Access Control is turned off.
- ccmanhattanFeb 07, 2024Star
Access Control turned off? What and where is Access Control?
- owlynFeb 11, 2024LuminaryIf you don’t know where Access Control is, then it was never turned on, so that would not be the problem. Is there a way to manually reset the WiFi on the thermostat?
- ccmanhattanFeb 11, 2024Star
According to Carrier, disconnecting it from the wall and waiting 30 seconds should do it. Have done this many times and still no luck.
