ccmanhattan
Feb 04, 2024Star
Orbi 970 and Carrier Infinity Touch Thermostat Model SYSTXCCITC01-A do not talk
Up graded router to new obri 970 and now Carrier Infinity Touch thermostat will not get on line. Have tried loT and main networks. Still no luck.
- Feb 13, 2024Read comments about a different thermostat and router and they used a $20 TP-link Access Point from amazon. TL-WA801N.Got it today and solved the challenge! Thanks all for the help!
Feb 07, 2024Guru - Experienced User
What security mode do you have set on the IoT network? WPA2 and AES only? Temporarily set security to NONE. Then see if the device will connect in the open. Re-enable WPA2 and AES after testing.
What channels are you using on the RBR?
ccmanhattan
Feb 10, 2024Star
WPA2 only option . Turned to none and still no luck.
- FURRYe38Feb 10, 2024Guru - Experienced User
IF thats happening, then there is some incompatibility between these branded controllers and this Orbi system.
- plemansFeb 11, 2024Guru - Experienced User
what actual error is the carrier giving you when you attempt setup?
Was looking back and didn't see it.
Is it able to see the wireless ssid?
Are you using any special characters or spaces in the SSID or password? Some sketchy IoT like thermostats have issues with special characters or spaces.
- ccmanhattanFeb 11, 2024Star
Error message: Unable to connect. Please check your password and network connectivity.
No special characters in SID or password
When asking thermo to find available networks, SID shows up as one.
Spent 1 1/2 hours on phone with Carrier tech and all she could conclude is that this version (A) has been replaced with the B and maybe it would be compatible. Hate to spend the $1,200 and find it is not.
