swisonline
Apr 30, 2025Aspirant
Orbi 970 AP
Hi, Why do the Orbi 973 (2 sat) in AP-Mode do not work when the internet is down? I do not understand why it would disconnect any devices? The Wifi breaks and I cannot access any LAN shares anymor...
- May 01, 2025
Seems that those you block are call to the mothership. I believe I saw that back in AX land years ago. Was attempting to block auto FW updates as they were causing problems and we couldn't stop that. I happened to notice that blocking some of those URLs caused the RBR to go PINK.
You'll need to not block those if you want the system to work right. Nothing we can do with the calling home of the mother ship stuff.
Apr 30, 2025Guru - Experienced User
What brand and model # is the host router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
The RBR and RBS required getting a LAN IP address from a host router in AP mode. If this service is lost then nothing will get any services, internet or LAN side services. You'll need to check with the host routers Mfr for help and support regarding there product and how to troubleshoot there product when problems arise.
- swisonlineApr 30, 2025AspirantActually.. this makes sense.
Thanks
Now,
Why does it not work,though, as soon as I block some Netgear URLs only. Internet is there.- FURRYe38Apr 30, 2025Guru - Experienced User
What NG URLs are you blocking?
