mhbare
Jan 10, 2024Apprentice
Orbi 970 Constant Reboots
Is anyone else still having issues with Orbi 970 continually rebooting at random times? I have no Pixel 8 to cause problems, and I am running on the latest 9.10.4.1 firmware. I've done multiple res...
- Feb 06, 2024
Nice. I think we can call this solved. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
JWS9518
Jan 11, 2024Luminary
Hi
I know you said you have done factory resets and all that, but after doing a factory reset have you unplugged all the sats and router along with the modem for 30 seconds to a minute. That may clear out any residue issues from the cache memory.
