mhbare
Jan 10, 2024Apprentice
Orbi 970 Constant Reboots
Is anyone else still having issues with Orbi 970 continually rebooting at random times? I have no Pixel 8 to cause problems, and I am running on the latest 9.10.4.1 firmware. I've done multiple res...
- Feb 06, 2024
Nice. I think we can call this solved. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
mhbare wrote:
Is anyone else still having issues with Orbi 970 continually rebooting at random times? I have no Pixel 8 to cause problems, and I am running on the latest 9.10.4.1 firmware. I've done multiple resets to factory defaults and manually reloaded software. I have been dealing with support since 12/26/23 and am still having significant issues.
Any suggestions? This is just ridiculous.
- mhbareJan 11, 2024Apprentice
Thanks for the information. I've supplied all of this info to customer support with distances, drawings of placement of router and satellites, etc. I've also provided logs from router, satellites, etc. I've been waiting on a response from engineering on issues, but at the same time, I'm trying to work through the issue versus sitting around waiting on them to provide a response.
- FURRYe38Jan 11, 2024Guru - Experienced User
Please provide us with feedback to the questions presented here so we can better get an idea of what your system environment is and we can better help you out.
- mhbareJan 12, 2024Apprentice
Calix Gigapoint 801G
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Using cable that came with router. I assume it's good. All other cables are Cat6A.
How many RBS are deployed?2
What is the size of your home? Sq Ft?3500
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteT‌‌here are 30-40+ between router and satellites. They are all on different floors in house. Old Orbi had 4 satellites with no issues.
I have not tried this. Will test this weekend.
Does this happen with both wireless and wired devices?Yes
What channel configurations are currently set on the router?I am using default configurations. I haven't changed anything other than the Wi-Fi network name from the default to the name I've used for 10+ years.
