mhbare
Jan 10, 2024Apprentice
Orbi 970 Constant Reboots
Is anyone else still having issues with Orbi 970 continually rebooting at random times? I have no Pixel 8 to cause problems, and I am running on the latest 9.10.4.1 firmware. I've done multiple res...
- Feb 06, 2024
Nice. I think we can call this solved. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 11, 2024Guru - Experienced User
Any other wifi 7 devices?
Have you noticed a pattern of it happening when a different device tries to connect?
With wifi 7 being draft (finalized but not updated yet) it could be something causing a loop. It could be a PITA to figure out which device is causing it.
mhbare
Jan 12, 2024Apprentice
I have not noticed any pattern or operation that causes it. As far as WiFi 7 devices go there is only one on my network currently. I have turned it off and issue still occurs. Right now it is wired versus wifi.
