mike698
Jul 14, 2024Star
Orbi 970 constantly drops wifi to devices
I purchased a new Orbi 970 router + 1 satellite for 6 weeks ago. I experience constant dropped connections to my connected devices including Echos, FireTV's iPads etc. My Configuration: 970 Rou...
- Jul 18, 2024
Yes that would be a good test to try and observe.
The one at 70 feet though, may need to move that in closer to the RBR.Also have you opened a support ticket regarding this with NG yet?
Jul 14, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
How is the RBS ethernet connected to the RBR? Directy to the back of the RBR? Or is there any kind of patch panel, wall jack or LAN switch in between them?
Which LAN ports are you using on the RBR and RBS to ethernet connect them to each other?
What CAT# LAN cable are you using between the RBR and RBS? CAT6A STP is recommended.
mike698
Jul 15, 2024Star
~1600
What is the distance between the router and satellite(s)
70 Feet
Have not tried, but will
No, just wireless
Default - but support had me change, still see drops
About 8
How is the RBS ethernet connected to the RBR? Directy to the back of the RBR? Or is there any kind of patch panel, wall jack or LAN switch in between them? There are some wall patch outlets between, but the same confg worked with the old device.
Which LAN ports are you using on the RBR and RBS to ethernet connect them to each other? 10G ports
What CAT# LAN cable are you using between the RBR and RBS? CAT6A STP is recommended. Cat6
- FURRYe38Jul 15, 2024Guru - Experienced User
What channels did you change to on the RBR?
Let us know if this still happens with the RBS turned OFF as a quick test.
Possible some odd issues with patch panels or wall out lets. 10Gb can be more sensitive than 1Gb LAN ports.
How many devices are connected at the RBS and RBR?
- mike698Jul 18, 2024Star
2.4Ghz = 01
5 Ghz = 44
Preforming the test with the RBS off now, will post the results - it can take a few hours to see a disconnect. I have noticed the disconnects happen on devices connected to either the RBR or RBS, not at the same time, but randomly.
Would disconnecting the wired backhaul also be a valid test - i.e., letting it revert to wireless?
RBR = 42
RBS = 32
- FURRYe38Jul 18, 2024Guru - Experienced User
