mike698
Jul 14, 2024Star
Orbi 970 constantly drops wifi to devices
I purchased a new Orbi 970 router + 1 satellite for 6 weeks ago. I experience constant dropped connections to my connected devices including Echos, FireTV's iPads etc. My Configuration: 970 Rou...
- Jul 18, 2024
Yes that would be a good test to try and observe.
The one at 70 feet though, may need to move that in closer to the RBR.Also have you opened a support ticket regarding this with NG yet?
mike698
Jul 18, 2024Star
What channels did you change to on the RBR?
2.4Ghz = 01
5 Ghz = 44
Let us know if this still happens with the RBS turned OFF as a quick test.
Preforming the test with the RBS off now, will post the results - it can take a few hours to see a disconnect. I have noticed the disconnects happen on devices connected to either the RBR or RBS, not at the same time, but randomly.
Possible some odd issues with patch panels or wall out lets. 10Gb can be more sensitive than 1Gb LAN ports.
Would disconnecting the wired backhaul also be a valid test - i.e., letting it revert to wireless?
How many devices are connected at the RBS and RBR?
RBR = 42
RBS = 32
Jul 18, 2024Guru - Experienced User
- mike698Jul 20, 2024Star
Thanks for the help - the issue ultimately seems to be the backhaul connection between the RBR and the RBS. Removing the wired backhaul seems to have resolved the issue, no issues since leveraging the wireless backhaul. To your point the 10G connection must be more sensitive since this is the same backhaul that was used on my previous RBK852.
- FURRYe38Jul 20, 2024Guru - Experienced User
And the 850 series is only 1Gb BH on ethernet.
Possible something on the wired maybe cuasing problems. My 970 series is online now with ethernet BH running.MIght make contact with NG support and see what kind of options they have for you. Running out of ideas to try here.
