kjx
Apr 25, 2024Apprentice
Orbi 970 Constants Reboots - Solved!!! (Router overheating is the cause)
I bought a Orbi 970 system with two satellites in mid-February. Had it hooked up to a 5-Gig symmetric internet service. Didn't have any issues for weeks as I only put a few devices on it while ot...
- Apr 27, 2024
Netgear opened a support case on their own seeing this thread and reached out to me.
Gave them all the details they asked for to help them investigate.
Hopefully this leads to a solution that helps future adopters of this hardware have a seamless experience because the Orbi 970 is spectacularly good outside of this.
kjx
Jun 03, 2024Apprentice
I don't have any update from engineering, except support reaching out asking if this is still a problem, and/or if anything has changed. For how much they charge for these devices, it's very unfortunate that this wasn't discovered prior to starting large-scale manufacturing - adding fans could have been so relatively easy at design time and wouldn't have cost much in the bill of materials.
tpgnavy85
Jun 27, 2024Tutor
This is the only known thread I have seen on this issue, and I also opened a case with Netgear on Tuesday over this issue. After an hour of analysis, they asked me to swap power supplies with one of the satellites and monitor uptime. So far after 2 days, no reboots, but mine have been pretty random over the last 2 months. I also measured thermal output of the RBE971, mine also shows about 90F under a relatively low network load. Have the RBE971 more out in the open now vice in an enclosure with a fan running over it, and it seems more stable right now. I also have applied engineering thinking, even asked support if I could try an engineering-level firmware with better logging to monitor the crashes (existing logging is just crap, only monitors minor events, which are lost when the router reboots), and they didn't sign up for that. I tend to agree there is an engineering flaw in the cooling system of the RBE971, and overheating seems to be causing the random reboots. But Netgear will not admit that at this point.
