kjx
Apr 25, 2024Apprentice
Orbi 970 Constants Reboots - Solved!!! (Router overheating is the cause)
I bought a Orbi 970 system with two satellites in mid-February. Had it hooked up to a 5-Gig symmetric internet service. Didn't have any issues for weeks as I only put a few devices on it while ot...
- Apr 27, 2024
Netgear opened a support case on their own seeing this thread and reached out to me.
Gave them all the details they asked for to help them investigate.
Hopefully this leads to a solution that helps future adopters of this hardware have a seamless experience because the Orbi 970 is spectacularly good outside of this.
kjx
Aug 04, 2024Apprentice
I'm the OP in this thread and I'm unable to reply to it with an update so starting a new discussion as the outcome is important to share --
"Orbi 970 Constants Reboots - Solved!!! (Router overheating is the cause)"
So, I finally received my RMA units (looked like a brand-new box with router and satellites, everything sealed). Replaced everything and sent all of the original equipment including satellites back. Netgear Armor started over with a 1-year sub.
Great news overall - sharing the exact update I left in the support case --
(A) Overheating & connection drops. (good)
I can confirm that the new equipment does not overheat – I stress-tested it with a 52 GB game download (peaking at 250 Mbps down). This was one reproducible scenario that caused the previous router would have issues with.
Even though everything is fine, for hardware longevity, I still plan to run fans over the router.
(B) WiFi-6E issues (resolved through satellite movement) --
The second problem where my WiFi-6E devices in a particular room would randomly lose connectivity (that engineering thought the logs looked weird on).
- This still happens on the new equipment. Same weird IP address assignment, etc.
- But I resolved this myself in the end by moving a satellite and placing it directly inside the room with direct line-of-sight to all 6E devices (going from a wired backhaul to a wireless backhaul).
- My devices near the satellite have higher pings (marginal at 10 ms) and marginally lower speeds (1.4 Gbps down to 1.2 Gbps up/down to my iPad) BUT the connection seems perfectly stable to multiple WiFi-6E devices in that room.
Aug 05, 2024Guru - Experienced User
Glad the RMA solved it.
Ya, I run a fan on mine all the time, regardless. Helps keep it cooler and helps with HW longevity in the long run.
Enjoy. 📡
- donawaltAug 05, 2024Hero - Experienced User
Interesting, another user with WiFi 6E issues FURRYe38 ….!
- charleswolfordAug 05, 2024Guide
Just an update on my similar situation. After trying all the detail from Furry, adding fans etc, still had restarts. Netgear started an RMA and I've set up the new setup and am monitoring. No issues so far but it's only 3 days. Hopefully it was the original router causing all the issues and overheating. Appreciate all the info in this forum.
- FURRYe38Aug 06, 2024Guru - Experienced User
Enjoy. 📡
