FiveOhWill
Mar 20, 2024Aspirant
Orbi 970 issues with new firmware 9.11.1.1
I'm having a lot of connection issues since this update was downloaded. Most of my devices won't connect and the devices that do have a slow connection. My satellite also doesn't want to connect. Anyo...
- Mar 21, 2024I've found the problem. The update severed the connection with the satellite which caused the connection issues with many of my devices for obvious reasons. I reset the satellite and reconnected it to the router. The problem seems to be fixed now. Thanks for the advice though.
FiveOhWill
Mar 21, 2024Aspirant
Mar 21, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
