Saif75
May 05, 2025Follower
Orbi 970 main router speed
I have the black edition of the Orbi 970 series with 2 satellites. When I am in the room with a satellite my wifi speed is 500 to 700, but when I am in the room with the main router, my wifi speed i...
May 05, 2025Guru - Experienced User
Usually just means your device isn't roaming to closer devices. Which isn't a big deal as each device has their own roaming protocol built in and if you're still getting a good connection, no need to roam and create drops/issues while roaming.
Most devices won't notice a difference faster than 50mpbs unless downloading massive files because even 4k only takes 25-50mbps.
