travisinfla
Mar 15, 2024Tutor
Orbi 970 on their 1.2 gp plan and getting WiFi speeds of over 1.4
Bs using with infinity and Orbi 970 on their 1.2 gp plan and getting WiFi speeds of over 1.4
- Mar 21, 2024
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 15, 2024Guru - Experienced User
Did you have an issue?
Not sure where you're going with this
travisinfla
Mar 15, 2024Tutor
I posted in wrong thread
