Tcrus
Feb 19, 2025Luminary
ORBI 970 Overkill? To much saturation?
I just purchased the 3 pack ORBI 970 and it says up to 10k sq feet coverage . My home is a 2 story rancher/4500 sq feet. Will placing all 3 of these cause saturation, should i downgrade to the 2 stat...
- Feb 19, 2025
Could. Might get the 3 pack and then deploy what you need. save the other RBS for later, or if needed.
KevinLiT
Feb 19, 2025NETGEAR Moderator
Hello Tcrus ,
Welcome to the NETGEAR Community!
Start your network with one Orbi satellite connected to your Orbi router. If there are any dead spots, then you may add the second Orbi satellite into your network configuration. Based on your network topology one Orbi satellite and a router will be fine.
Please be sure to follow to the recommended Orbi placement in the link below:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Best,
Kevin
Community Team
