Tcrus
Feb 19, 2025Luminary
ORBI 970 Overkill? To much saturation?
I just purchased the 3 pack ORBI 970 and it says up to 10k sq feet coverage . My home is a 2 story rancher/4500 sq feet. Will placing all 3 of these cause saturation, should i downgrade to the 2 stat...
- Feb 19, 2025
Could. Might get the 3 pack and then deploy what you need. save the other RBS for later, or if needed.
Feb 19, 2025Guru - Experienced User
For that size of home, the RBR and one RBS would work. 30 feet distance in between the RBR and RBS is starting distance at least.
Tcrus wrote:
I just purchased the 3 pack ORBI 970 and it says up to 10k sq feet coverage . My home is a 2 story rancher/4500 sq feet. Will placing all 3 of these cause saturation, should i downgrade to the 2 station model? Or put one out in the gargage (not heated, prob in the low 20's at night). Any advice is welcomed. Crude pic of sattelite placements included in pic 🙂
- TcrusFeb 19, 2025Luminary
I currently own the Orbi 850 Series AX6000 - my wifi download speeds are around 380 down and 32 up. This is on a 1.2 gb connection. I have the router and 2 sattelite stations with my AX6000. The 970 woudl kind of future poroof me for wifi down the road and probably double my speeds on wifi?
