Tcrus
Feb 19, 2025Luminary
ORBI 970 Overkill? To much saturation?
I just purchased the 3 pack ORBI 970 and it says up to 10k sq feet coverage . My home is a 2 story rancher/4500 sq feet. Will placing all 3 of these cause saturation, should i downgrade to the 2 stat...
- Feb 19, 2025
Could. Might get the 3 pack and then deploy what you need. save the other RBS for later, or if needed.
Tcrus
So would adding the 2nd sattelite interfere cause saturation/slower speeds? I am in a bind because the 3pack was on sale and sale is off so the price for the 2 pack is about the same!!!
Feb 19, 2025Guru - Experienced User
