dkstruck
Dec 07, 2024Tutor
Orbi 970 RBE971 dropping offline since firmware update to v9.12.4.16
I updated the firmware on my Orbi 970 (RBE971) router on 5 December 2024 and it has been dropping offline periodically since the update.
Dec 07, 2024Guru - Experienced User
Is this the RBR unit?
Is the bottom LED turning on RED or PINK when this happens?
How often is this happening?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
dkstruck
Dec 08, 2024Tutor
Tech support stated this morning it's a software bug. They had me wipe the config and setup from scratch. Haven't seen any disruptions but Monday will give a better indication when I have some real time applications running.
But to answer your questions the base unit (RBE971) showed offline in the Orbi app a few times. I have 2 satellites so there is more than ample coverage for the house.
The outages are random; both timing and duration. It kept dropping a laptop wifi connection. My wired desktop lost connectivity too.
I haven't been checking the lights; rather I have been using the Orbi app and a desktop browser to monitor status.
- FURRYe38Dec 08, 2024Guru - Experienced User
What is the size of your home? Sq Ft?I've found sometimes new FW updates may not work with older configurations. Can cause problems, why I usually factory reset the system and setup from scratch with out loading any saved backup configurations when I see issues like this. Something also posted about in the FW update post I usually post and pin to the top of the forums.
- dkstruckDec 19, 2024Tutor
After resetting the Orbi to factory and configuring from scratch the problem seems to be isolated to my iPhone 16 Pro Max running iOS 18.2. It is not affecting my iPad mini which is also running iOS 18.2.
- FURRYe38Dec 19, 2024Guru - Experienced User
So all other devices are keeping online along with the RBR being online?
Have you tried resetting the networking settings on the iphone under General>Transfer or Reset>Reset>Reset Network Settings?
