cundy
Dec 04, 2023Follower
Orbi 970 Router Wired network issues
My Orbi 970 router keeps dropping directly connected Ethernet cables after about 45-60 minutes. I turn it off for a bit and then it is good for another 45-60 mins.
I called support and that did not help very much.
The router is connected to an LG C3. I have permitted all traffic for the TV.
I have swapped cables, bought new ones and tested other devices. The issue persists…
Anyone else have this issue? Thoughts?
1 Reply
Any progress on this?
Might update if you see this, if you haven't already:
