cdjonescpa
Jan 26, 2025Aspirant
Orbi 970 Satellite stuck on V9.10.0.2, failing all FW attempted Upgrades!
I purchased a remanufactured Orbi 970 Satellite from Amazon which has clearly been registered previously, and this may be my issue; but upon being received, FW was set with V9.10.0.2. I r literally tr...
Jan 26, 2025Guru - Experienced User
How about a 30-30-30 reset on the RBS.
Then don't let it connect to the RBR, try doing this with it and see if it will take a FW load?
If this fails, the RBS maybe faulty and should be returned to NG. Something you could check with NG about and see if there is an RMA option.
