cdjonescpa
Jan 26, 2025Aspirant
Orbi 970 Satellite stuck on V9.10.0.2, failing all FW attempted Upgrades!
I purchased a remanufactured Orbi 970 Satellite from Amazon which has clearly been registered previously, and this may be my issue; but upon being received, FW was set with V9.10.0.2. I r literally tr...
cdjonescpa
Yes the chk successfully unzipped/uncompressed, and I have also tried multiple FW versions…. All fail or it says “service unavailable” given I try to automatically update directly with router IP address. I’ve also tried the satellite IP address as a direct manual update method. It WILL go through the motions like it is going to update and then when “ready” again and I login with IP again, it’s still set at the durn FW V9.10.0.2
I plan on just returning for a replacement via Amazon. My other Orbi satellite and router are on the most current V9.12.5.3 and updated no problem so must be a bum unit
Jan 27, 2025Guru - Experienced User
Ya I'd get that RBS back to Amazon and see if you can find another RBS.
Only other way you could try is maybe see if the TFTP functioned worked to force load newer FW on it, however not sure if that would work either. RBS should take a FW load from it's self service web page but if it's not, something is faulty with this RBS.
