ponus1357
Oct 24, 2024Aspirant
Orbi 970 Series Quad-band WiFi 7 Mesh
I am in the process of setting up a new home network and plan to use the Orbi 970 mesh system with 3 satellites. My plan is as follows: - Router in the basement connected to the Optical Network Ter...
ponus1357
Oct 26, 2024Aspirant
I’m not suggesting that 10Gbps is not enough, of course it is. Nor would it be likely that you would overwhelm the system.
My concern is that the satellite connections would become unstable if you mix the front and back haul connections by passing them through the same switch.
Other users have reported problems with the satellites flicking between wired and wireless when setup in this configuration. My initial gut was to split it out but after speaking with my AV guy he assured me this was overkill (caveat being he has no experience with this specific system). Clearly, I was still skeptical as I reached out to the community.
Thanks for your inputs. I will report back once I have it all setup and hopefully working
Oct 26, 2024Guru - Experienced User
I have my DISH Hopper system along with several other devices on same 10Gb switch along with two RBS ethernet connected on 10Gb connections. Have had zero issues with stability.
