ManojKancharana
Apr 29, 2025Aspirant
Orbi 970 Series Quad-Band WiFi 7 Mesh
while configuring Orbi 970 Series Quad-band WiFi 7 Mesh 3-Pack we are unable to see 6GHz configuration settings in wireless settings page FW version : V9.12.3.3_1.2.20
Apr 29, 2025Guru - Experienced User
Got a screen capture for this?
Where are you looking for wifi configurations? Web UI or Orbi App?
FW is behind as well:
ManojKancharana
Thanks for your response,
we tried to configure through webGUI and APP ,however we are unable to configure the 6GHz(bandwidth/SSID/Password/channel/BE/AX/mode)
even we upgrade to latest FW, 9.12.5.3 still we did not see any changes.
along with 6GHz, we would like to change the bandwidth for 2.4GHz and 5GHz as well, but we are unable to find the options
- ManojKancharanaApr 30, 2025Aspirant
additionally, we would like to know, is it possible to configure Satellites as a router?
- FURRYe38Apr 30, 2025Guru - Experienced User
No.
- plemansApr 30, 2025Guru - Experienced User
1. there isn't anything to change on the 6ghz. On the 5ghz, about all you can change is the channel (a little bit) but it won't impact much because of the width of the channels being used.
2. you can't turn the satellite into a router.
3. the orbi is a pretty simplified mesh system without much to change in it.
