mn_a4's avatar
mn_a4
Orbi 970 vs Orbi 860 through cement walls
Hi! I tried browsing through existing posts, but could not find a similar topic.
I currently have an 860 which was fine in the old house, but recently moved into a house with cement exterior walls and now cannot get reliable wifi to the patio. Will the 970 provide better performance through the cement walls? I don't need a lot, but maybe extending coverage an additional 20 more feet past what I currently get through the wall would be good.
An RBS50Y in extender mode was suggested, but I don't think they are in production anymore and the prices I see on the internet are ridiculous.
  • plemans's avatar
    Wifi broadcast power has been maxed out for quite a while. And you already have a top of the line system.
    Its not going to penetrate any better.
    You're best option is to connect an outdoor access point hardwired. This could be using an ethernet run, a powerline connection, or using a moca adapter (ethernet over coax). That'd be the best way to get outdoor coverage.
    Trying to use a wireless backhaul will run into the same issue you're currently having.
    Sometimes its worth the investment for a hardwired connection
  • I guess I was hoping that the new antenna of the 970 would provide better penetration.
    I did manage to put an 860 satellite outside in the patio right by a window that was able to daisy chain to one of the inside satellites. There's a large overhang so it should be protected enough from the elements.
    • FURRYe38's avatar
      Is the RBS860 exposed to the outside environment? Orbi systems are not designed for outside use, even if under a over hang or covering. Exposure to humidity, cold and hot temperatures in a out side environment will not be good for the RBS that are designed for indoor use. If you need a RBS out side, you should look into a outdoor weather proof electronics case.
      • mn_a4's avatar
        mn_a4
        Thanks for the tip.
        Maybe I'll try it inside sitting right at the windowsill pointing out.
