Dilby
Apr 10, 2024Guide
Orbi 970 Wifi issues with specific devices
I have moved from a pretty much rock solid 5 year old system to this >£2000 system with intermittent issues. My setup is one wired satellite and one wireless satellite in exactly the same physical lo...
Apr 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Are you using the Main WLAN for all wireless devices or are you using the separate IoT network for wireless devices?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
