Dilby
Apr 10, 2024Guide
Orbi 970 Wifi issues with specific devices
I have moved from a pretty much rock solid 5 year old system to this >£2000 system with intermittent issues. My setup is one wired satellite and one wireless satellite in exactly the same physical lo...
May 28, 2024Guru - Experienced User
Any progress on this?
Dilby wrote:
I have moved from a pretty much rock solid 5 year old system to this >£2000 system with intermittent issues. My setup is one wired satellite and one wireless satellite in exactly the same physical locations as my previous system. The issues seen so far are:
1) Intermittent disconnection of Google Nest Hub Max. Usually resolved itself within a minute. The device is located almost immediately below the wireless satellite through a wooden floor.
2) Disconnection of Sky Q mini-box (wireless to the main Sky Q), requiring power cycling to get it to connect to the main Sky Q box. As far as I know, Sky Q uses it's own wireless network for bridging the two boxes, but still relies on the home network for internet connectivity/streaming
3) Nest Outdoor camera dropping connection intermittently. This camera should be in range of at least two if not three of the Orbi units.
4) iphone dropping connection and having to "forget network" and reconnect to get it to connect. This has only happened twice in the last week.
