AliazRob
Mar 01, 2024Tutor
Orbi 970 wired backhaul disconnected satellites
Today I received my brand new Netgear WiFi 7 (ORBI 970) 3-pack. This set is replacing my WiFi 6 (ORBI 860) 3-pack. My configuration: - 1 router, 2 satellites (firmware: V9.12.1.2 (latest)) - AP...
AliazRob
Jun 27, 2024Tutor
Hi Furry,
What’s so special about this vLAN ID? What does it do? And if I configure it like this how do I connect my broadband router to my network?
Jun 27, 2024Guru - Experienced User
Apparently is a VLAN that the Guest Network is on as well as other things. I guess Orbi FW doesn't know how to work with or thru of a managed switch is in the middle.
Inputting this into the managed switch seems to resolve issues with RBS being ethernet connected to managed switches. I've checked this on a MS and GS series switches and my 970 RBS ethernet connected to the switch with this configuration now works correctly.
This is only put on the managed switch that is in between the RBR and RBS that ethernet connect to this switch.
