jomoOKC
Jun 24, 2024Follower
Orbi 970/SimpliSafe
Is the Orbi 970 Series quad-band compatible with the SimpliSafe Home Security system, which can only use 2.4 GHz?
CrimpOn
Jun 28, 2024Guru - Experienced User
Of course. Unlike some Internet of Things (IoT) devices with poorly written smartphone apps that struggle with setup, the Simplisafe alarm system setup is accomplished by selecting the WiFi system on a screen and entering the password using the keypad. I have a Simplisafe system connected to an older Orbi WiFi system, and the connection process was simple.
(Having a display screen and a keypad greatly simplifies the process.)
