Jackpine's avatar
Jackpine
ORBI 971 DOESN'T CONNECT TO STARLINK
Has anyone successfully got the Model 971 to connect with Starlink? I recently purchased ORBI 971 at the recommendation of Netgear and it doesn't connect to our Starlink ISP. Have been working with N...
  • FURRYe38's avatar
    Jul 07, 2024
    Others have posted that using a non managed NG switch, i.e. GS-105 or maybe a GS-305 connected between the ISP adapter and RBR with out any other devices connected to this switch got the Orbi router working with this ISP adapter.
    Power OFF the ISP adapter/modem along with switch and Orbi router, then back ON starting with the ISP adapter/modem, switch, then Orbi router.
