edwardckl
Jun 27, 2024Aspirant
Orbi 972 and EE TV Box Pro - IPC6023 Error ??
Hello all, I used Orbi 972 with EE Broadband in UK without problems. However, when I tried to connect it to EE TV Box Pro and viewed the TV channels, the TV Box shows IPC6023 error. In the r...
edwardckl
Hi,
I tried to contact both ISP (EE) and NG support. EE said they cannot provide support for 3rd party router whilst NG support said they will pass my case to another team to follow.
I am using firmware v9.12.3.3. My router is connected to Openreach hub directly and the TV Box is connected to my router by wifi.
Thank you.
Jun 27, 2024Guru - Experienced User
Ok.
What brand and model# ISP modem or ONT do you have connected to the RBR?
- edwardcklJun 27, 2024Aspirant
I connected the router to the Openreach modem (ONT) directly. The modem was installed on the wall of the house when we moved in.
- FURRYe38Jun 27, 2024Guru - Experienced User
What model# ISP modem or ONT do you have connected to the RBR?
Might try this, set a IP address reservation for this one device on the RBR, then us this IP address and input this in to the RBR DMZ, enable DMZ and apply the change then see if the device works.
- CrimpOnJun 27, 2024Guru - Experienced User
Truly annoying that EE will not discuss the issue. Internet search for "EE TV Box Pro IPC6023" turns up lots of hits.
Posting the question in the EE Community forum may be more likely to get useful information than this Netgear forum.
It also might be worth asking a generic question of EE (rather than mention Netgear) such as, "Can the TV Box Pro be connected to a customer WiFi router or does it have to be connected to the EE box?"
