Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those on the beta and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especially important, if...
jasmas
May 03, 2024Aspirant
I have an ATT router in front with WiFi and most features disabled and configured to put the outside IP on the Orbi router MAC. Orbi is configured with DHCP-PD and appears to work great.
I do not see a way to configure custom ipv6 Dns in this configuration which is a shame because I prefer to use Cloudflare for both v4 and v6.
- jasmasMay 03, 2024AspirantThe above is running v9.11.1.1 in North America.
- FURRYe38May 03, 2024Guru - Experienced User
Do you see any IPv6 DNS options if you select the DHCP or Auto DHCP from the IPv6 menu?
Thanks for the feedback...
- FURRYe38Jun 03, 2024Guru - Experienced User
FYI, new FW available:
I do not see a way to configure custom ipv6 Dns in this configuration which is a shame because I prefer to use Cloudflare for both v4 and v6. - homegaragesolutJul 03, 2024Aspirant
Regarding Orbi and IPv6 feedback and experiences, many users find Orbi’s IPv6 support to be robust and reliable. Setting up IPv6 on Orbi routers is typically straightforward through the admin interface. Users report improved network performance and future-proofing for their home networks. However, some have encountered occasional compatibility issues with certain ISPs or devices. It’s important to ensure your firmware is up-to-date for the best IPv6 support. Overall, Orbi’s handling of IPv6 tends to be positive, providing seamless connectivity and leveraging IPv6’s benefits like more efficient routing and enhanced security features.
4o
