bigkahuna01
Apr 27, 2025Aspirant
Orbi doesn't see an internet connection when connected to 2.5gbps port on modem
I have a new internet provider (EzFiber) and they have installed a Nokia modem and my plan supports 2.5 Gbps and their technician validated that I am getting 2.5 Gbps on the modem. I have connected m...
- Apr 28, 2025
The modem was changed yesterday because of some ISP issue. There were setting on the old modem containing my Orbi's MAC and IP Address that were causing a conflict with my replaced modem (New Profile) that were resulting Orbi not getting an IP Address. 2nd level support cleared the old modem's profile from the system and everything is working as expected. Thanks to everyone for their suggestions.
CrimpOn
Apr 27, 2025Guru - Experienced User
A lot of people already have gigabit switches. On Amazon, a TP-Link 8-port gigabit switch is under $20.
10G switches are a LOT more expensive.
With the fiber modem supplying 2.5G, I would opt for a less expensive 2.5G switch.
I am assuming that this Orbi 970 is well past the 90 days of 'complimentary support', and thus not long eligible to open a case with Netgear support?
Would be interesting to see how the router describes a direct connection to the modem. (should be 2500M/Full)
bigkahuna01
I tried Orbi directly to Nokia modem and it is not getting any IP Address as shown in the following images. Went back to Nokia --> Eero 6E 1 Gbps --> Orbi and it is getting IP Address and connects fine to the internet.
Statistics:
- CrimpOnApr 28, 2025Guru - Experienced User
Strange that Show Statistics reports the connection rate as 1000M/Full. and the "up time" as 6 hours, 26 miinutes
I would be more comfortable if
- Both modem and Orbi are powered off.
- Cable connected from modem to Orbi
- Modem powered up.
- Orbi powered up.
- Observe the router LED
- When the LED turns magenta or off, connect to the web interface, Advanced Tab home page and record the same information (Internet port, Show Stastics)
- FURRYe38Apr 28, 2025Guru - Experienced User
Did you set up the VLAN configuration for your ISP that maybe needed on the Orbi RBR first?
Also did you power OFF the ONT for 1 minute along with the RBR after it was configured for VLAN for the ISP, then turn one the ONT and RBR? You might contact the ISP and ask for there help in getting the RBR configured correctly to connect to the ISPs ONT. There maybe special configurations needed that they can help you with.
- bigkahuna01Apr 28, 2025Aspirant
I followed the procedure as you mentioned and here are the screen shots:
There are no specific steps related to VLAN configuration for your ISP for Orbi but I will call Ezee Fiber and update...Thanks
Might also give a non managed switch a try as well. NETGEARs MS105 is a 2.5Gb supporting non managed switch.
Hoping that the ISP can clear this up though.Keep us posted.
Tried switch but no luck. ISP sees the MAC Address of my Orbi and also sees that they are not able to assign it an IP Address. They will get back to me by EOD today. Hopefully something will change
K, seems like this is some odd ISP handling issue. Hoping they can help figure it out.
- FURRYe38Apr 29, 2025Guru - Experienced User
Figured it was something on the ISP side. Glad they found it and fixed it.
Enjoy. 📡 - bigkahuna01Apr 29, 2025Aspirant
Thanks for this 🙂
