brianld's avatar
brianld
Apprentice
Oct 26, 2023
Orbi max clients
Can someone clarify the maximum number of clients supported? I read from the product announcement that the Orbi 970 series "supports up to 200 simultaneous devices".
A few questions:
1. Is the 200 simultaneous across all satellites/router?
2. Default LAN DHCP range allows for ~250+ IPs.  What happens if/when I have more than 200 clients on the network?  I assume there's no hard limit?
Thanks as always for the knowledge sharing.
    • brianld's avatar
      brianld
      Apprentice
      Thanks.  That KB article helps, though it now raises the question as to why the "Pro" system allows for 512+ clients and the consumer Orbi allows for 250+.  Not a big deal for me either way yet - currently sitting at about 60 devices on my LAN at any given time, and probably have only hit 75 maximum concurrent users peak.
      • FURRYe38's avatar
        Pro is tuned more for business class which may have more devices to work with. Home class usually won't see much more than 50-100 Devices on average.
