elfoo
Nov 27, 2024Aspirant
Orbi models release dates?
I'm looking to replace my orbi devices since they are no longer supported by net gear. I dont want to get something that is already 5 yrs old and close to EOL.
I've been trying to find the orbi models release datseebut cannot find anything. Also, anyone know what netgears support commitments are?
Can find general dates by looking at the initial FW release notes for each Orbi model to see approximate dates on when they first appeared. Otherwise, there isn't a listing for dates.
Orbi AX first appeared in 2019.
Orbi AXE around 2022.
Orbi BE was just last year.
https://www.netgear.com/about/warranty/
https://kb.netgear.com/000065798/How-do-I-check-if-my-NETGEAR-product-is-under-warranty
Just because they're a bit older, doesn't mean they don't work fine.
What speeds do you pay for?
How many devices do you have?
What do you use it for (gaming/streaming/etc)?
If you've only got a 100-250mbps connection, the older AC orbi's will still rock it fine.
If you're pushing gigabit +, then its time for an upgrade.
